The needle to stem is a fairly tight push on fit. You can simply hold the drum and rotate the needle while lifting and it will come off. A long surgical clamp thing ( roach clip ) can be use behind the gauge screen removing this needle. It might not be needed reinstalling. Just push it on and dial it to zero but, Be warned... Opposite the needle is triangle. There should be a dollop of white melted plastic like substance on the back of this. All of this is needles counter balance. Bend the triangle at all and the white stuff will crack/fall right off. Speedo wont act right without it.
