D Dadeland Dodge Member Joined Sep 22, 2023 Messages 14 Reaction score 27 Location The Villages, FL Dec 21, 2023 #1 Has anyone changed on of these bullet cables, mine is stuck in the transmission
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 15,210 Reaction score 12,555 Location Northern Colorado Dec 21, 2023 #2 Are you trying to salvage the old one? If not you could use vice grips on the outer sheathing at the base of the part that goes into the transmission and use a slide hammer to pull it out Just have to ask .. You did remove the clamp? Most likely, IMHO, the rubber o rings is what is stuck in the trans.
D Dadeland Dodge Member Joined Sep 22, 2023 Messages 14 Reaction score 27 Location The Villages, FL Dec 21, 2023 #3 No, this is the new one, the clamp is removed, I'm thinking vice grip and twist, the cast looks fragile to me to use a slide hammer, just looking for any insight. Thanks for the input!
