67barracuda
I need some guidance in how to remove the speedometer needle. I want to swap the one from a 120 gauge to my 150 gauge. I can't seem to find any info on the web about this.
You didn't say what speedometer. In most cases... the tringle like flag opposite the needle center is a counter balance. More of a place for counter balance. Once the needle is removed you will see a dab of white epoxy on the underside of that flag.
Bend the flag, epoxy breaks off, counter balance lost. This happens too easily.
I use a long thin surgical clamp ( forget the name of it ) to grasp the tube beneath the screen and work it off the stem.
Hemostats.
