Spitfire Header Install
bandit340
Active Member
Just started to test fit Harolds headers and found out the rt side interferes with the 90 deg oil filter adapter. If I remove the adapter ,do I need to change anything ? 1970 340 Duster
I run the 90 degree adapter with spitfires. I had to turn it a little towards the torsion bar and go with a shorter filter. I undserstand that most header installs are not exactly the same. Just wanted to let you know that it was done on my 63 dart.
So just loosen up the attach bolt and angle it down.....Ok Ill try it
