Spread bore Air-Aid?
Mopar General Discussions
  1. QuickDart360
    QuickDart360 Well-Known Member
    1,177
    425
    Apr 5, 2014
    San Antonio
    Local Time:
    11:32 PM
    Hey guys I came across a air aid spacer. Its a 4 hole type only difference is that each hole has a spiral or "threaded" finish on inside area. Supposedly to help air fuel mixture draw in like a tornado or spinning effect if you will. Just curious to know what you think. Gimmick or is it something that can help.
  2. rigger3006
    rigger3006 Well-Known Member
    760
    195
    Aug 6, 2013
    bc
    Local Time:
    11:32 PM
    i used one, basically a 4 hole spacer, i guess one would need a dyno to really know for sure,id lean toward gimmick
    • Agree Agree x 3
    • QuickDart360
      1,177
      425
      Apr 5, 2014
      San Antonio
      Local Time:
      11:32 PM
      Hey rigger have you installed the 292 cam in your motor? I know different subject, but wonder how did it work out? If not let me know when you get around to it. I plan to use same cam in my car.
    • Mattax
      Mattax Just the facts, ma'am FABO Gold Member
      10,804
      6769
      Feb 7, 2013
      Phila. Pa
      Local Time:
      12:32 AM
      It may disrupt the boundry layer but most of the flow is toward the center of the opening.
      And if it did send any sideways, what's that doing to the cylinder to cylinder distributor?
      • Agree Agree x 1
      • QuickDart360
        1,177
        425
        Apr 5, 2014
        San Antonio
        Local Time:
        11:32 PM
        So not a very effective power enhacer then. Ok I guess I'll pass!:eek:
      • rumblefish360
        rumblefish360 So close, yet so far away FABO Gold Member
        38,404
        10025
        Jun 21, 2005
        New York, on a Island
        Local Time:
        12:32 AM
        I’d pass.
        • Agree Agree x 1
        • rigger3006
          760
          195
          Aug 6, 2013
          bc
          Local Time:
          11:32 PM
          not yet, still 2 ft of snow in front of garage.i want to run some baseline tests after i install 391s for the 355s, airgap and 750 qf are coming off for a holley strip dominator and a custom built carter superquad. then i'll do the camswap.i will post my results, should be good for a digital tongue lashing!lol
        • QuickDart360
          1,177
          425
          Apr 5, 2014
          San Antonio
          Local Time:
          11:32 PM
          Sounds good!! Your build is so close to mine. I got a 360 stock stroke windage tray, KB107 .30 over pistons, stock x-heads (redone), 280/474 mopar cam, 2 plane intake with modded 850 thermoquad, 727 transmission with turbo action valve body and FTI 3400-3600 stall converter and 3.55 rear gears & auburn gear sure grip.
          Will go to 3.91's & auburn gear sure grip. Holley strip dominator, 292 mopar cam, and very possible dynamic 4200 stall converter I already got!:steering:After this I can go ricer hunting and eat BMW's for breakfast!:D
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          61,995
          34200
          Jun 7, 2010
          Georgia
          Local Time:
          12:32 AM
          Snake oil
          • Agree Agree x 1
