Spread Bore On Offenhauser?
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Does anyone know of a spread bore adapter that bolts directly to the slant 6 Offenhauser intake manifold? I've looked but cannot seem to find anything. I thought I'd ask before I start modding something.
I think the Offy intake has 4 small holes that line up with their adapter plate. that being said, that could be modified easy enough.
mine was cut out before I got it.
It's the same bolt pattern as the early GM small 4 barrel carburetor. I'll modify what I have if I have to. I wanted a dedicated plate, that way I'd have one for square bore and one for spread bore. I may be able to make what I have work for both.
Mr Gasket ( Holley) # 1932 adapter should work l believe.
Nope. That won't bolt to the intake. It'll bolt to the adapter on the intake, but then the hood won't close. I need something that bolts directly to the intake.
RRR,
My Offy catalog shows #5270 as the 225/ 4 bbl intake, sq bore mounting carb pad. The Offy #5830 adapter adapts QJ to square bore, fully divided, not open.
Check out Moroso adapter there was a dyno test somewhere that showed s marked improvement in flow over others
You running a 170 or a 198? Doing this just for fun?
:poke:Says the Member who's obviouosly not on RRR's "following You" list, lol!
Would that be the same as the Clifford base pattern?
These I purchased from another Rusty on .org, and were part of Bob Stepp's collection of parts. Appears to be a modded std spread-to-square 'dapter, needs a little professional "refinement" to line-up w/base screws, & a little work w/a spot-face/end mill to finish for some allen-head screws. Placed over other for reference.
Anyway RRR, if that's the same base pattern, You're welcome to this half finished cadapter for the postage. I sure ain't gonna use it....
RRR,
That's the issue. I don't have room to keep stacking adapters.
Now that has possibilities.
