srt-8 jeep manifolds
hemidart67
1967 dart pro-touring
Brantford On
Are these SRT-8 Jeep manifolds?????
No. Those are for an eagle headed 5.7 I believe. What chassis are they out of?
That said, they probably flow fairly decent.
A local guy says they are off his SRT-8 Cherokee and they didn't look like a jeep manifold to me so i thought i would ask.He Just replied and said they were off his 2012 SRT-8 Cherokee
I saw a post over on FBBO that has what looks like a cast iron manifold and he said they came off of a 6.4l SRT8 Cherokee.
Do they have any casting numbers on them?
Unfortunately given the way the collector points nearly straight back, I doubt (have NO first hand knowledge) they'd fit.
I would love to hear if it does / doesn't though.
Regards,
Joe Dokes
Here are some Jeep SRT8 manifolds for a smoking deal (not mine):
[ame="http://www.ebay.com/itm/CHRYSLER-DODGE-MOPAR-6-1-HEMI-OE-EXHAUST-MANIFOLDS-/221469610938?&_trksid=p2056016.l4276"]Chrysler Dodge Mopar 6 1 Hemi OE Exhaust Manifolds | eBay[/ame]
Disclaimer - these only fit with aftermarket coil over and rack & pinion conversions, and require a few mods still at that.
I have done a mock up of SRT8 manifolds in an early A using coilovers. The only issues are very little (1/8 inch) clearance on the pass side and the bell housing needs to be trimmed by the starter to give the manifold room on the drivers side. The coil over conversion can be done using a Dillenger support kit for the shocks, and coil overs. This allows the notching of the subframe where the T bars were for exhaust pipes to run, which is a great mod allowing the pipes to be tucked up under the car for better looks.
I plan on using the fuel cell I already have in the trunk, cut out the spare wheelwell and replace with a flat piece of steel and put the mufflers under there for a decent look.
