People always say to put the batt on the pass rear, but come on....
You need to put the car on 4 corner scales and see how much weight is on each corner, then you'll know where you need the extra weight.
When I did mine I ended up needing the battery on the drivers rear.....
You can also load the rear differently by playing with the torsion bar adjustment.fyi
