Staggered Coy C-5 Wheels for your A-Body!!!
Super T
Thisfieldistooshort
Aurora, IL
Rating - 0%
0   0   0
Coy C-5 wheels, gray spokes, polished lips. Very low-mile Falken tires. 17x7 with 215/50-17 Falken tires on front, 18x8 with 245/45-18 Riken tires on rear. 5x4.5 bolt pattern. Rolled smooth for the brief time they were on the car. Fronts have very minor scuffing on the corners from fenders under full compression, one tire has small spot of paint on it from other work in the garage. Wheels came on the Scamp, just have no use for them as we will be going with totally different wheel/tire setup on the car. Very minor marks in clearcoat on polished lip, you have to look for them to see them. Valve stems behind the spokes for a super clean look. Balancing weights installed on back as well. This is $800 in wheels, never mind the value of nearly-new tires. This combo got about 2,500 miles on it from the time it was bought to the time it was taken off of the car. High-res pics available. Local sale or buyer pays shipping (around $175).
$450.
Put me in line in case you don't sell to the guys before me.
thanks,
FYI, the fenders were rolled. The rear end was also a 58"-ish Ford 8"... that's also for sale, has a 2.73 gear, open diff, and a weld-on disc brake kit from Southwest Speed already installed. I will measure backspacing tonight.
The back spacing on these wheels is 4.25" on the front and 4.5" on the rear. The wheels were $175.00 for the rear ea new and the fronts were $125.00
