[WANTED] Stahl A body 303 headers
cpearce
Edson
Hello everyone,
I have a set of Stahl sb Mopar A body headers for my race Duster, I believe part number is 303 although mine are stamped 904 217 on driver's side flange. These have 1 tube that goes through the wheelwell on each side. Due to internal corrosion several of the tubes have become quite thin. Since the car has been modified for these headers I would like to find another set. Does anyone have a set, or know of where I could find a set? Any help would be appreciated. Thank you.
If you strike out on those I believe Hedman Husler makes a similar header with the one pipe through the fender well. Might be close.
You can always get some tubing and prebent turns and make your own, wont be that hard if you only need a couple tubes
Jere Stahl was still making headers about a year or so back. Google them & see if they can help you out.
