[SOLD] Stainless slant six valves 1265 + 567 EPN
Cuda416
South, TX
Below is copied from another listing from 5 years ago which looks as though it was pasted from the MFG description. These are the same valves.
Engine Parts Network stainless full set intake and exhaust new in the wrappers for you slanty hot rod.
Below is input for Ex. but you will get all 12
Application is Dodge, Chrysler, Plymouth 225" slant six engines, all years..
One set of 6 GENUINE EPN (engnbldr) oversize performance stainless steel performance exhaust valves. These are oversize head, yet stock stem diameter and length.
Application is all Chrysler slant six engines, note valve seat mods are required to use these. GREAT for when your exhaust seats are worn out, just machine larger and fit these in, no need for oversize valve seats.
SPECS: Intake is 1.7". Stem diameter is 3/8ths, accepts stock valve locks, stock length..
SPECS: Exhaust is 1.440". Stem diameter is 3/8ths, accepts stock valve locks, stock length..
MATERIAL: One PIECE forged EV8 grade stainless steel, fully non-magnetic. The stems are hard chrome plated, the head is undercut, fully polished with a 55Rc hard wafer tippet to stop tip wear.
And there really are none finer made, these are massively strong! THIS valve is UNIQUE to our company, Engine Parts Network.!
These accept the stock valve stem oil seals, fit the stock guides, and stock springs and retainers.
I'd like $125 +shipping for the full set of 6 int and 6 exh
Well phooey. No PM, your inbox is full. Can you make room and shoot me a PM on these please?
