73Swinger18
Anyone know what the stall would be on this stock 904 converter that came with my '73 Swinger with a 318?
Thanks. I installed the Comp Cam PN 20-223-3 and it states that it works best with a 2000 stall.A good, crisp, 318 2bbl can take some of the "high stall" converters from the factory to over 2000 (brake torque method). Others as low as 1700.
Yes, and I actually had a factory stall that was the 2320. With good biting tires, you could stand hard on the brake and about get it there.My 69FSM lists it as 2100 to 2320(lol);brake-stall
Didn't look up the cam choice, but if you have taken away torque from the 318, then you won't get the 2k.Thanks. I installed the Comp Cam PN 20-223-3 and it states that it works best with a 2000 stall.
The cam is 268/280 duration and .477/.480 lift. It's bored .020, new flat top pistons, stock heads with larger valves (1.88/1.60), Weiand Stealth intake, Holley 600, and long tube headers. I hope it works when it's all said and done. Half the car is still in pieces in the garage.Didn't look up the cam choice, but if you have taken away torque from the 318, then you won't get the 2k.
Too late. Slapped the two together yesterday and installed them. Took today off after screwing with the headers!Before you bolt that puppy together, you aughtta calculate the exact Static and Dynamic compression ratios. Nothing is worse than expecting the big cam to blast off......and then it doesn't
If your pistons are too far down in the hole, you may be in for disappointment
Knowing beforehand that it will blast off, is way better than hoping;waaay better.
Sealed Power flat 3.930 cast pistons.What kind of pistons? I'd imagine compression would be at least 9:1 unless they're stock replacements, which is around the minimum with that cam... if that's the case the combo will work, but not nearly as well as it could...
Not sure if any of that info is here Sealed Power Cast Piston (Carton of 8). All I saw was 1.720 Compression Distance. Not sure exactly how much he took off the head. I think it was just enough to clean up the surface. I'll have to ask him tomorrow.Part number? Compression height? Distance below decks? Dome/dish volume? lol... these values are necessary to know compression. Were the heads shaved at all?
It's has an open 7.25" diff with 2.71 gears and 205/70R14 tires.Man I hate to break it to you... those look like stock replacements. It says "8.5:1 CR" in the specs which can change with a lot of other factors but still means something, and it's not good lol. That 318 is gonna be a turd until at least 2500 RPM, what gears you got in the back?
Unless my math is off, that's only 0.09" shorter than the Keith Black pistons. That doesn't seem like a lot. I wonder what the stock piston compression distance was in 1973?Those look to be stock low compression pistons. 1.810 compression height is the common one for 318's. Odds are your pistons are about .100" low in the hole. If you are at sea level 8.5 SCR pistons with your cam choice nets you a low 7.0 to 1 DCR at sea level. This will effect how hard the car launches. A higher then stock converter around 2800rpm might be a good choice to mask the low rpm power.
Haha! I'll have to see how much he took off the deck and heads tomorrow and the gasket size used to see if I made up any compression there.Oh Nooooooooo! lol
It's gonna be sh*t.
Anyone know what the stall would be on this stock 904 converter that came with my '73 Swinger with a 318? View attachment 1714980618
