Standard vs Rally dash frame
Duster71
Active Member
Does anybody have a picture of a Rally dash frame without the gauges in it? I want to see the difference between a rally frame and a standard frame. I have a standard but would like to change over to a rally dash. If it's TOO much trouble, I'll just go with the RockyMountain conversion.
Hello Duster71. Here is a pic of the instrument cluster frame out of my 71 Duster.
it looks like i would have to cut a portion of my dash to do the swap if i wanted to.... how are the pins for dash setup???? i have a spare dash i could cut up if i absolutley wanted the ralley dash.....
The dash wiring is different as well. You could likely figure out which wires go to what pins with a wiring diagram, but would require some work and time to get right
