Starter issues
Paul Davidson
Texas
I'm starting to go through the process of firing up my motor it's a fresh built 408 and I wanted to get some oil flow through the motor so I pulled the plugs and spun the motor over and got a horrible noise from the starter. The starter is a Dakota style starter and a lakewood cast bellhousing has anyone had issues like this and another question is how far should the starter gear be from the flywheel
Video with audio would be a big help. Did you make sure the starter in squarely bolted up?
Easiest way to wipe a cam if it’s a flat tappet. U may have to grind on the starter or bell to get it to fit square to the bell. This is very rare. Most likely like stated above u didn’t have it in place right. Kim
