I would only see that being accepted at races that allow a 2-step, as it basically does the same thing. None of the footbrake races I run allow 2-steps so that device would be frowned upon. Interesting idea though. If someone wasn't paying attention nobody would notice because the engine wouldn't be studdering like if it was on a 2-step.
This would be classified as cheating with an electronic devise,as the solenoid needs electronics to work.JMOA friend of mine told me a couple of racers are using a idle stop solenoid to hold steady rpm while staging in foot brake. Anyone use this?
It called FOOTBRAKE class for a reason they're trusting that your footbraking the car..any device that holds the rpms should be considered CHEATING!!..then again maybe some guys don't know how to launch a car..
At the 6 tracks I race at it is illegal to use a line lock at the starting line or have one hooked to a button.(It has to be on a toggle switch). That is if you want to run in the foot brake class.The other class is Pro class and electronics are allowed and trans brakes.By some of the comments I have read. Would you consider a line lock illegal. It operates with electronics. NHRA doesn't. Play back tachs. NHRA doesn't Just curious. And how much advantage are you really gaining with a solenoid. You still have to cut a light. You still have to shift right. Your car still has to be consistent. Whether you use your foot or a solenoid to hold rpm at the line. BIG DEAL. You still have so many other variables to contend with. And I even haven't talked about the biggest variable the WEATHER!
Sounds to me like the sanctioning body has not addressed this
in a non interpretable way or the techs are not doing their jobs inspecting.
Could it be considered a throttle stop, maybe set up
like a fast idle cam on a choke system.
Your absolutely right..no electronics in footbrake classes..so in other words running that device is CHEATING...
all the tracks in my area allow that (0-13.99) when i used it i would pre stage flip my switch bump the throttle, it was set at 1200 then start to bump in with my foot resting on the throttle, what do you think this guy is doing [ame="https://www.youtube.com/watch?v=WeWOtiYrAas"]American Bracket Racer Episode 1 - YouTube[/ame]I race at 2 tracks in my local area, the nhra track calls the footbrake class NO BOX, allowing 2 steps & transbrakes & line locks, the IHRA track calls it non electronics, no 2 step or transbrakes allowed, im old school, true footbrake, we are racing for enjoyment, u will not win enough money to support your habit
