Steering Box Size Comparison
Borgeson Universal Company
  1. Joeycurl
    Joeycurl Active Member
    42
    24
    Oct 28, 2019
    Bay Area,CA
    Local Time:
    2:46 AM
    Hoping you guys can help me clarify how much space (clearance) i will gain by using your steering box 800127 from the stock? I have a big block 440 in my 72 demon, and have beyond super tight fit between headers and steering box. See the attached pictures. 20191114-steering rack and headers1.JPG 20191114-steering rack and headers2.JPG
  2. BORGESON
    BORGESON Sales/Tech FABO Vendor
    14
    23
    Dec 12, 2019
    South Carolina
    Local Time:
    5:46 AM
    • Thanks! Thanks! x 1
    • Joeycurl
      42
      24
      Oct 28, 2019
      Bay Area,CA
      Local Time:
      2:46 AM
      Thank you for the link. I was looking at the specs and cannot determine the main housing diameter, this would be the round housing that is closest to the header. Given the same mounting points, knowing the diameter would tell me how much more clearance i will gain. Can this be shared?
    • Keith Mopar
      Keith Mopar Mopar Nut
      2,866
      897
      May 15, 2005
      Calgary AB.
      Local Time:
      3:46 AM
      It looks like the main housing at it's 3.94 inches per his diagram. This is at the largest section. My buddy did a borgenson conversion on an E body and he gained about 1/2" to the closest tube, running TTI's on a 440. I did have some pics but can't find them. If I come across them I'll post them up.
    • Joeycurl
      42
      24
      Oct 28, 2019
      Bay Area,CA
      Local Time:
      2:46 AM
      Thank you! Would appreciate those pictures or is anyone else had pictures. BTW, I couldn't see where you got that dimension from
    • Joeycurl
      42
      24
      Oct 28, 2019
      Bay Area,CA
      Local Time:
      2:46 AM
      One more question, does the steering box just drops right in? or does the headers have to be removed prior to installation?
    • CarWash
      CarWash FABO Gold Member FABO Gold Member
      48
      25
      Apr 2, 2008
      Hollywood, California USA
      Local Time:
      2:46 AM
      The Headers can be a problem, unless you spend the extra money on a set of TTI's. We tried Hedman, not right, then Headers by Doug and still had to move the front tube... about an hour extra. The Borgesion A-Body quick ratio power steering box does save space, but what an awesome upgrade from he 60 year old MOPAR Technology. I couldn't recommend Borgesion more, simply the best! At the same time we changed out to the IDidit A-Body tilt steering column.
      • Like Like x 2
