jamie_aitken
Regina,Saskatchewan,CAN.
Is it possible to swap the wiring out of 70 column-shift into 71/72 floor-shift column?The reason I ask is I was told that the column would fit but there would be a problem with turn signal switch,as 70 has 2 tail-lights,and 71/72 has four.Are the 71/72 brake and tail-lights seperate,or does one bulb do both like the 70?(I know there are four tail-lights in the bumper,but I can't remember if they all light up or are two back-up lights?).Thanks,Jamie.
