John H.
Active Member
Need to remove horn ring from 1967 dart gt convertible. Any ideals. Ring is loose and floppy.
Thanks. Got center cap off and took wheel and tightened the 3 screws on back. Back to new again. Appreciate your help.That chrome horn ring does look like 1 piece. The very top ( about 1/2 inch thick ) portion will come off. Hold the wheel, grasp the center cap and rotate it counterclockwise about 30 degrees to unlatch it.
Thanks. Got cap and tightened screws on back side.tighten the screws under the center cap
Thanks. Got it tight.That chrome horn ring does look like 1 piece. The very top ( about 1/2 inch thick ) portion will come off. Hold the wheel, grasp the center cap and rotate it counterclockwise about 30 degrees to unlatch it.
