Sticky clutch pedal
1973dusterkid
Watch This
Buford Georgia
Ok so on my 73 duster 360 4 speed.
McLeod 10.5 diaphragm clutch
the clutch pedal gets sticky when you press it only after you drive if and get it good and hot.
Is it getting stuck on the floor or is it binding part way up? Diaphragm pressure plates don't like too much travel, they get to certain point and the spring doesn't want to push back anymore. If it's binding part way up then start checking the linkage ends for excessive wear and the Z bar for worn bushings.
Why not phone the McLeod tech line?
They deal with this all of the time, better than asking us hacks who just guess.
My guess is that the clutch is out of adjustment, FWIW.
