Still looking for brake lights and turn signals... HELP!
Electrical and Ignition
  1. OlDuster
    OlDuster Well-Known Member
    115
    0
    May 25, 2004
    Salem, Oregon
    Local Time:
    9:45 AM
    I pulled the steering wheel and checked out the turn signal switch. I have a horn and emergency lights. I guess I have power then, correct? No bulb problems, either? I cannot find ANY power to the turn signals. I have checked it out and taken the switch out of the hub. I cannot find a wire (other than the horn and emergency switch) that has power. Where is the power coming from? I have power to the brake light switch. When I press the pedal, it comes on and has power. I am told that the power goes through the turn signal switch and then out to the correct bulbs. Any ideas on this one boys?
  2. six pack
    six pack Well-Known Member
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    9:45 AM
    Power comes from the fuse to the brake switch, when the brakes are applied power flows through the switch to the turn signal switch and is re-directed to the rear bulbs.
    Your hazards work?
    Checked power from your turn signal fuse?
    Make sure you load the circuit with a lamp to make sure you are getting enough current flow through it. a bad connection may light a cheap light but not flow enough current to do the job.
  3. Marty
    Marty 383 S
    54
    0
    May 22, 2004
    Toledo, Ohio
    Local Time:
    4:45 AM
    The best way to check this out is to some how get a Factory service manual and get a ohm meter and check each circut from begining to end and the diagrams for these years are pretty easy to follow.
    Maybe someone from the board that is close by that can help.
  4. LM23P9B
    LM23P9B Well-Known Member
    340
    1
    May 23, 2004
    Sheridan, Oregon (Ory-gun
    Local Time:
    1:45 AM
    What car/year are you working on? Ray
  5. orangedust
    orangedust Well-Known Member
    221
    0
    Jul 16, 2004
    San Diego
    Local Time:
    9:45 AM
    I am having almost the same type of problem on my 70 Duster 340
    I have all working lites except for no parking lites. I changed the headlight switch and turn signal switch but still no parking lites, I have headlites though. I wish I could help you out I will let you know if I get mine going. Anybody with any more things I could check? :cry:
  6. 17dartandbroke
    17dartandbroke Well-Known Member
    184
    0
    Jul 14, 2004
    Luling, LA
    Local Time:
    9:45 AM
    i have the opposite problem. i have running lights, and headlights, but no turnsignal/brakelights
  7. six pack
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    9:45 AM
    Have you checked your fuses with a test light?
    Checked power at the headlamp switch from the fused park light circuit?
  8. orangedust
    221
    0
    Jul 16, 2004
    San Diego
    Local Time:
    9:45 AM
    Six pack:
    I checked the fuses and they are good but once in a while, when I am trying to diagnose the problem the tail lite fuse will pop. I was wondering why I found a box of fuses in the glove box. Anyhow, I have a direct ground short somewhere along the circuit. Electrical work is not one of my best areas, the only other thing I noticed that it is an original 4 spd
    car and under the hood I found the automatic transmission column linkage attached to the steering column! I bought the car from the original owner pink slip and all, but they passed away before I could find out if the column was ever changed. :scratch:
  9. six pack
    424
    0
    May 22, 2004
    Alberta Canada
    Local Time:
    9:45 AM
    I'm not sure on A bodies, but B and E bodies with 4spds did have linkage to the column in 1970 as you had to put the car in reverse to get the key out. I would start isolating some wires, check the harness(all of them) to see if they have rubbed through somewhere, been piched, aftermarket accessory wired in, etc.
  10. ted_sweet
    ted_sweet Well-Known Member
    734
    12
    Aug 4, 2004
    albany NY
    Local Time:
    4:45 AM
    the turn signal switch has nothing to do with the parking lights.
  11. orangedust
    221
    0
    Jul 16, 2004
    San Diego
    Local Time:
    9:45 AM
    Finally, got the tail lites working!!! When I had the exhaust put on at the
    shop one of the other mechanics was an electical troubleshooter, I said the
    hell with it, fix the lites. Like I said before electrical gremlins is one of my
    gray areas. He found a bad wire through the lite switch, at first he thought
    I had a weak fuse block, but I think this problem existed for a long time,
    before I got the car. Anyways, its done I have dash lites and tail lites,
    and he charged me 50 bucks!!
  12. dart4forte
    dart4forte FABO Gold Member FABO Gold Member
    4,866
    1381
    May 28, 2004
    Mesa, AZ
    Local Time:
    9:45 AM
    Check your HL switch. the connector may be loose causing a short
