abodyhotrod
- Joined
- Sep 17, 2007
- Messages
- 292
- Reaction score
- 2
hey just noticed oil pressure seems to be dropping at idle to below 14, 13 seems low but still max is 60, any suggestions
Yes the general rule has always been 10 psi for every 1000 rpm. LAte model cars typically run less oil pressure but 14 psi at idle is just fine.
Also, don't take the gauge as gospel, get another and verify especially if you are using the factory gauge.
just thought id throw that out, thanks for the info. im learningNo it's not a problem, but, Mopar does sell one that has a hardened tip and is a good part to upgrade with. It should be used in a race car or heavy street strip car. Just incase kind of thing.
