GREEN DART 5
I've got a good running, all stock, 5.9 in a 1996 Ram 2500 and want to swap it into my '71 Dart with an A833. I have some questions about my parts list.
I will be purchasing a flywheel from American Powertrain FWCH-10004CS. Is this the best route to take in order to keep the FI? Should I be worried about the 1/2" notch I have to cut into the bell housing for the crankshaft position sensor? Would a trigger on the harmonic balancer work better?
What is the best fuel pump to use and where is the best mounting location?
Would I have to change my fuel line to 3/8"?
I know I have to change the oil pan and pick up. Also, going to have to look for a power steering bracket from a van. Anything else I'm missing?
Magnumswap has been very helpful!!!! Thanks FABO!!!
