Stock fuel tank with sump
ronw
cashtown,Pa.
Does anyone have pic's or suggestions on how to plumb a holley(12-125) electric pump and route to the front of car with fuel lines. instructions say to have the pump at fuel level but how would you mount it? Ron
with abracket ! muuuwa haha
One time I mounted the pump and HP-1 filter connected with a short solid nipple just behind the bumper, and on another car I mounted the pump on the inside of the frame rail by the leaf spring mount. On the first one the tank was tapped on the bottom so it was easy to run the line back to the pump. The second one used the stock fuel line location in the tank.
what you need is to mount the pump part not the motor near the bottom of the tank, some what close to the bottom. that way the pump will have the fuel in it to pump. you can mount the pump anywhere below the full fuel line if you have to. use a line size at least one number larger on the suction side of the pump.
I finally got it figured out on how and where to put the pump bracket. It took awhile to fab but I wanted it to look professional and not just slapped together. It 's tight and keeping the pump low enough to gravity feed it, with a stock tank and having moved the springs in with a mini tub. Now need to plumb from tank to pump with combination of pipe and AN fittings
