Stock Manifold?
thejohnnyguy
Young Gun
Charlotte
Just wanted to know if anyone could help me figure out if the manifolds I pulled are stock or not... the driver's side mani has # 3614395 on it, and im about to go snap some pictures to put on here...
.............Its a 73-74 A body mani....left.....kim.......
The other one looks different and I can't find a number on it... here's the pics I just took:
Pass.side casting number is on the side that faces the block when installed. You might be able slip a small mirror in between the head and the manifold and read the number.
Don't know anything about the accuracy of this site,
http://www.mymopar.com/extcastnumb.htm
But according to the page above, it looks like you have a 318 manifold off a 1972-73 Dart (3614395) for the left side.
If you can't take the right side off, you might also try using some kid's modeling clay to get an imprint of the casting number on the opposite side if you can't see it with a mirror.
Thanks Dan, I used that trick to get the engine block casting numbers off a motor that I was looking at and couldn't quite see from underneath. The clay cost me about $2 and was well worth it as I discovered it wasn't the engine that I wanted.
MyMopar.com lists exhaust manifold numbers by year and side, only it doesn't list by power steering or not. Look at the chart: http://www.mymopar.com/extcastnumb.htm
I'm also trying to find a stock manifold for my '68 Dart. Mine has power steering. The picture you took looks like it might fit. Does your Scamp have power steering? If so that number might work for me. I don't need it to be correct stock, just to fit. I don't want to spend the $ on a new set of headers.
Great idea!! I never heard of that but I may use it some day. Thanks
Marleydog,
They don't have a listing for P/S or no P/S because the manifolds fit either one.
