Stock Rocker Shafts VS.
71Duster
Alberta Canada
Will I notice a huge change/difference in a mild 360 from stock rocker shafts to racer brown rocker shafts?
I dont think so!
Are you running a hyd cam? You would need to change push rods too and I think the $$ is spent better in other areas of the car.
Rollers are good but the are really for those whom really need them as a result of load engine type etc..
my 2 cents..
I already have them and they ate a set of spacers, I have new spacers coming but so far I've had NO luck getting that magical sweet spot of lash so I have no lifter noise.
I have thoughts that if these giv eme more greif to e-bag em and get some pushrods made up and run my stockers. Just wasn't sure if there would be a nite and day difference.
you won't notice any difference on a mild setup.
Well I was tired of the issues from my Racer Brown shafts and after it ate the teflon spacers IE: Melted and waiting for the new aluminum ones I tossed my stock ones back on.
No loss of power -noticeable- Off the line seems a little better actully and the engine is quieter.
Go figure
