Stop in for a cup of coffee
Find any treasures?
Nope. I did buy a cross member for my 66 satellite, the welded in piece. Mine has some rust. I was going to patch the small rust spots....But I might just replace the entire thing. It's not like it will be the only piece getting welded in....
That early powerwagon is awesome. It has a first gen Cummins
Looks nice enough to drive as is. If you pay more than $10 large for it you will never get $60 out of it when you have $50 in it for the restore. Now days it takes $50 to do a car.
Lots of buzz around it.....and the power wagon.....It was tough to get pictures of it without anyone in the shot...
Thanks for the heads up on the disc brake set up.
Timing just isn't good. I have so many parts now, and I'll be lucky if I get half of it done before spring.
I'm close that price per pound but just a smaller steak... Grass Fed/Grass Finished New York strip ...
Living in Iowa I am spoiled with corn fed. I can taste the difference between grass, ground corn, and corn silage. I like the ground corn the best.
Wow. THat's all I can say is Wow!
"I started my Hemi a few times over this past week and am wondering if
I made the right choice on the plugs. I have autolite AR 53 plugs in it now but they
seem a bit on the cold side but im not a plug reader. After a few runs i pulled them and they are black and it’s running or at least smells rich. I’m running the edelbrock AVS2 carbs 650 cfm and have not done any jetting as of yet maybe i need to. Could the plugs be to cold? this is a 496 stroker with stage V
intake. Oh and am running it on 93 non ethanol pump gas."
Indiana is top 5 in beef production. Problem is supply is being routed to larger pop centers
Black plugs matter..:thumbsup:
