Morning kiddos..
Karl was on here last night around 9:30 up to his usual antics...
I wents swimminhg there by SF once at half moon bay, man that water was cold!
Well the wife wants me to drive her to the dentist in a few since it is snoe flurries. OK we are taking the Tikey truck then! HF is two blocks away and the time for a new tool box is right!
The beaches in San Diego County were loaded. When I lived down there as a kid, come about Labor Day we didn't go to the beach, frickin' water got cold about then
Ya, so i added about 500 lbs to the back end of my power wagon, made it worse. It wouldnt stop at all. Tires were fairly new too.Get yourself a gang box to weigh the back end of that thing down too
If it was my luck, they wont have stock.Well the wife wants me to drive her to the dentist in a few since it is snoe flurries. OK we are taking the Tikey truck then! HF is two blocks away and the time for a new tool box is right!
Yup been a decent truck just a few small issues. Want to keep it. Always need a 4WD around here.Good Old Tikey Truck. You sure have gotten use out of that truck
Prob have to do that with the Dakota, dont know yet. Tell you what it does lock up and goes straight though Hopefully the inspection is done today. Its on Dean time!I suppose at a point it makes sense as it reduces downforce on the front tires and braking effectiveness.
I would toss a few 25 pound sandbags (100 pounds) over the wheel wells
This one is the 88 w150, no need dam thing weighs 5KGet yourself a gang box to weigh the back end of that thing down too
I really have to compare the rear suspension on that to a plain Dakota. It does have a floating rear sway bay. Of course the links had to be replaced. Plastic with a metal insert.I always filled the gas tank on the Ranchero when heading to one of those illicit after hours street activities to have any hope at all of getting some bite out of the drive tires
Probably more likely to high center on snow
Put it this way I put factory mud flaps on it the moulded ones that match te flairs, they hit going over a speed bump, but then again I pit the 235/55 tires on it which were the other recomended since I could not find 255/55/17 anywhere for a half decent price. Definately has some sort of handling package. Stupid things like shocks were different from a reg one.How much lower is it than the "standard" Dakota?
I call that turtle. Put a turtle on a fence post. Same idea. No, im not cruel, i’d never leave a turtle there.Probably more likely to high center on snow
At least i can see them. The frogs are duffucult to see, so i go slow where they usually hide. Meeces on the other hand, i drop deck and hammer down.But then you wont run over it with the mower!
