straightlinespeed
Sometimes I pretend to be normal
Definitely consider yourself lucky buddy! You dont think someone sabotaged it do you?
that would be good. I have a pretty good idea now, but only saw 2 believed to be original. Not sure when I will do the carpet install. Gonna be a nice weekend here. think I want to switch back to the body and paint. try to finish a few details and shoot the grille area, fender bolt flanges trunk seal area and tail light area. That pretty much will let me assemble the whole car. Whenever down the road I am ready to paint I will just tape off most of it vs. tearing it all apart again. I will leave the emblems off and prob still pull off some easy stuff (side markers, maybe tail lights..)Hey Keefer, i got a 73 Swinger at work that has whats left of its original carpet. I'll see if i can snap a pic for you sometime this morning. I pulled the column out but haven't disturbed much else inside..
I like pancakesPssst, I think it was the pancakes comment.. Not that it was bad, but we are all hungry so we went out for breakfast.
unlikely, they would have had to jack it up to do it, while the durango has decent ground clearance, the Limited edition has running boards and a front air dam as well as a rear difuser, all that means that unless your no thicker than 6 inches, you aint getting under itDefinitely consider yourself lucky buddy! You dont think someone sabotaged it do you?
I like pancakes
i tell you what...
sure - until you realize that grandma was beating off Indians with them...Mmmmmm, pancakes....
Hey that's my cousins cousins daughter in law of the fouth removed cousin in law!
Picked up Eddie's Dart from the exhaust shop yesterday. Headers hooked up and x-pipe is in:
purtyPicked up Eddie's Dart from the exhaust shop yesterday. Headers hooked up and x-pipe is in:
way to go - - so how long DO you normally go between showers...Hey folks. Guess who's pretty damn pleased with himself. Finally got to use my welder for some good. Now it's REALLY time for a shower then drop the boy off for soccer camp all weekend and then head out to the summer house to reee-laaax all week-end long.
View attachment 1714944605 View attachment 1714944606
See if these help at all. I have every reason to believe this is factory 73 Swinger stuff..that would be good. I have a pretty good idea now, but only saw 2 believed to be original. Not sure when I will do the carpet install. Gonna be a nice weekend here. think I want to switch back to the body and paint. try to finish a few details and shoot the grille area, fender bolt flanges trunk seal area and tail light area. That pretty much will let me assemble the whole car. Whenever down the road I am ready to paint I will just tape off most of it vs. tearing it all apart again. I will leave the emblems off and prob still pull off some easy stuff (side markers, maybe tail lights..)
View attachment 1714944633 View attachment 1714944634
thanx. That's the first one I saw with the notch down behind the arm of the pedal. Can't see how that actually matters. I think they just tossed them in and some nut with a blade jumped in after them. From what I have found so far I think as long as it stays under the bracket of the gas pedal the rest is freestyle.See if these help at all. I have every reason to believe this is factory 73 Swinger stuff..
While it is kinda good to actually 'do something' at work, enough is enough!!! I'm ready to go back to 50 hr work weeks!talk about being busier than a one legged man in an *** kicking contest..
As long as you get full movement of the pedals, you're good. Unless of course your a concours resto kind of guy...thanx. That's the first one I saw with the notch down behind the arm of the pedal. Can't see how that actually matters. I think they just tossed them in and some nut with a blade jumped in after them. From what I have found so far I think as long as it stays under the bracket of the gas pedal the rest is freestyle.
