Say, if a head is cracked, what would be the signs when you tear down the engine?
Oil in with antifreeze(not always) , visible cracksSay, if a head is cracked, what would be the signs when you tear down the engine?
The machine shop wanted to know if they should pressure test them and since I don't have their history, I'm hesitating. It isn't cheap but then again, doing the work on crecked heads is an even worse deal.Oil in with antifreeze(not always) , visible cracks
LOL repeater!Wouldn't a mag flux be good to find any cracks ?
But not the internals of the head. I talked to them about that.Preassure testing I am not familiar with at all. Would that just check the chambers? I know Mag flux does everything, chambers, ports, guides etc.
Have them sonic checked or magnaflux.The machine shop wanted to know if they should pressure test them and since I don't have their history, I'm hesitating. It isn't cheap but then again, doing the work on crecked heads is an even worse deal.
I wrote to the seller and he said the engine looked really nice inside and I guess he would have noticed if water had leaked into the oil, right?
The only way to check that is gonna to be to sonic test thenBut not the internals of the head. I talked to them about that.
Pressure testing isn't commonly done, normally a diesel or industrial thing as opposed to the standard gas engine. Essentially it's like flow testing by bolting the head down to a plate and testing not only the chambers, but the water ports, oil passageways and intake and exhaust ports. Done one by one, time consuming and not cheap. Essentially filling the head passages with pressure and waiting to see if any psi bleeds off. Sonic testing can do it much faster which is why pressure testing isn't done much these days.Preassure testing I am not familiar with at all. Would that just check the chambers? I know Mag flux does everything, chambers, ports, guides etc.
Usually it's done on the high mileage OTR rebuilds for semis. The thought process is that if you fill the chamber/passageway to its rated psi and it holds without busting a hole, the head can be reused. The same with the block though normally they just sonic test the block as the highest risk of a blow out due to fatigue is in the headI never ran into it, makes sense Diesel engines with high pressures.
Well not really, we posted at the same timeLOL repeater!
Haven't ordered seals. I'm thinking I'll let the machine guy supply them. That way I can be sure they're in there ok. Same with the seats. I may not replace the seats after all. I'll let him decide.You have new seals Anders? Prob can get away with the springs tested.
Wait, not seals. I was thinking of guides.Haven't ordered seals. I'm thinking I'll let the machine guy supply them. That way I can be sure they're in there ok. Same with the seats. I may not replace the seats after all. I'll let him decide.
I'm a little confused by the different stem diameters available. Kind of freaking me out. I don't want to get valves that have too much slop in the guide. Or too little.
Yup, Thats how it is here. Feast or famine. I have a small shop at my house. I usually try to do a couple a jobs a week. All easy stuff Brakes, Axels, Pm's etc. I dont really need the money, but it helps , parts for the Mopars. Sometimes Ill go two weeks without a call. This past week I had 8 calls and 8 jobs in the last two weeks. Yup, Feast or famineBusy week, last week i bought my shelving, guy had it loaded on his trailer and said take truck/trailer to bring shelves home.when returning truck i noticed brakes felt rough. Mentioned it, he gave me a list and dropped off truck. Guess im making my money back-and then some.
Out to pick up take out for dinner, guy sees me, bringing 2 plow trucks for service /repair.
Malibu coming for exhaust manifold.
I had one call last week,and no appointments, this week is full up.
