dukeboy440
Cause the uso is the only place open 24 hrs in an airportHey Karl the wife had a in planned layover in O'Hare last night, no ide why she left a message from the USO!
It's an AC/DC TIG welder with HF start so yeah, it's a pro welder.
It was like 1am here she left the message.
I thought I sent you one?Guys, what is the large pipe thread on the front of the LD340 intake? Is it 3/4" NPT? I can't remember.
A lot easier to find, too. Thanks.That sounds right, but I'm not positive on that...
If you have a choice, get a straight pipe thread tap, not a tapered one...
If you tap too deep with a tapered pipe tap, the hole gets larger and you may bottom the fitting out in the hole...
A straight pipe thread is not depth sensitive and will work fine and you don't have to worry about the depth when you tap...
Found an NPT one. $110.They must be fun to find over there.
Ok, hang onto it. No rush. If I would bother to make one, it won't happen for a while.Since threeish for me. Hey if you want theat spare board it is yours will not work for mine.
