I have a brand new Strange S60 rear-end. This was going in my 72 Scamp but things are crappy for me right now so I am unable to complete my project so Im cutting my losses and selling everything I have for it. It is the correct width for A-Body Mopars that are mini tubbed and have had the springs moved inboard, or for cars that are running ladder bars or link type suspensions. It is narrowed to 49 flange to flange which is the width it needs to be if you are running a 325/50/15, or 315/60/15 tire (or any tire shares these demisions) with a 10 wide wheel and 3.5 backspace. Was put together with no expense spared and with the best of parts. This axle is as strong as they come. I was going to be running it behind a procharged low deck indymaxx pushing 1000Hp. I have all the receipts as well. I have close to $2000 just in the parts, thats not including set-up labor. Everything is brand new 0 miles. There are no spring perches or brackets on it yet.
Specs:
49 axle flange to flange
Big ford housing ends
Strange 40 Spline Pro-Race axles
5/8 Chromoly Studs
Strange Lightweight Pro-Race Spool
Richmond 4.10 gears
Chromoly 1350 Strange Yoke
All new Timken Bearing and seals ect
Gear set-up was done by Don @ six states in Portland Or.
Im asking $1200 for it. My price is firm.
I can send pics if you are truly interested.
Its located in Portland Or
Specs:
5/8 Chromoly Studs
Richmond 4.10 gears
