stripe size 65 Barracuda
Tadams
Tadams
nc
I would like to know the proper size of the stripes. I believe they are 6inch, with a 1inch gap and a 1inch stripe on each side. This would make a total of 10 inches wide. Does this sound correct? I have seen one locally that has a 10inch stripe with the 2 1 inch stripes as well. The second would be 14 inches wide.
Thanks for any thoughts
If its the same as on a 66 I can measure later this afternoon and let you know.
Not sure if they are the same. Check the measurements if the you have time, no rush
Thanks, I'm a few weeks a way from painting, but trying to get everything all ready.
65 and 66 are definetly different! Here's a pic of my 66!
Mine is a 66 but has the thinner 65 stripe. I like the 65 stripe better.
Not sure what I'll do when I get around to body and paint.
You guys are amazing. Thanks for the information.
65 and 66 racing stripes are different
1965 is a large solid stripe with two thinner stripes (3 total) with 5 color options
1966 has thicker stripes with two thinner stripes ( 4 total) with 6 color options
You could just order a kit from phoenix graphix for a little over $120
Would it be better to order a stencil, or just measure and tape where the stripe would be. It seems fairly simple if you measure correctly. $90 for a stencil seems to be a lot to me. The stripes are straight. What do you guys think?
I see they got you straight. I never noticed they were different. I forgot to measure mine when I got home. The stripes on my 66 are like cosig's.
