Stroker Performance Review
Mopar Racers Forum
  1. cudascott
    cudascott Now I have a Hemi
    1,766
    621
    Jan 11, 2012
    TN
    Local Time:
    12:17 AM
    post states power port 190
  2. '63GT
    '63GT Well-Known Member
    1,482
    1525
    Jun 9, 2018
    Turlock, CA.
    Local Time:
    9:17 PM
    I think he said 190's
  3. B3422w5
    B3422w5 Well-Known Member
    1,283
    1268
    Feb 9, 2017
    Portage michigan
    Local Time:
    12:17 AM
    not aware there is more than one choice. They are all 190 cc head. Just a matter of what spring you want on them. Big block has two choices, just the one for smallblock
    • Agree Agree x 3
    • Garrett Ellison
      Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
      2,922
      2301
      Jan 1, 2018
      Southwest VA
      Local Time:
      12:17 AM
      As stated, nothing that ensuring you have adequate fuel delivery, a properly sized and tuned carburetor, and timing adjustment wouldn't help out. A custom converter certainly wouldn't hurt anything, either. You could potentially see more mph hour if your present converter loses efficiency and is "blowing through" in the fat part of the torque band. I don't expect it to be as far off as the carburetor (if any at all), but I'm only chipping in because I didn't see mention of what spark plugs and gap you are running.
    • pittsburghracer
      pittsburghracer FABO Gold Member FABO Gold Member
      4,056
      7342
      Apr 20, 2016
      Freeport, PA.
      Local Time:
      12:17 AM
      It doesn’t take a really big carb to run better than he is now. I ran 9.80’s with a 750 Holley on my W2 headed 408 shifted at 6400-6600 rpm.
      • Like Like x 2
      • Agree Agree x 2
      • B3422w5
        1,283
        1268
        Feb 9, 2017
        Portage michigan
        Local Time:
        12:17 AM
        that is true. I only gained a hair better than a tenth going from a 750 to that 1025 race demon. But everything adds up. His convertor i know is killing that combo though.
        • Agree Agree x 4
        • j par
          j par Well-hung Member
          24,692
          12975
          Jul 2, 2014
          Portland Oregon
          Local Time:
          9:17 PM
          I'm also not sure why you're not in the 118-120 mph range.. I would think it would like four or five more degrees of initial timing... I've got to say the carb isn't in big enough as well...
          • Agree Agree x 1
          • 70aarcuda
            70aarcuda Master Hoader of SBM FABO Gold Member
            15,743
            4279
            Jan 16, 2005
            las vegas
            Local Time:
            9:17 PM
            asking about the springs....as the lower price version spring presure at 120 seat pressure.....
            • Like Like x 1
            • B3422w5
              1,283
              1268
              Feb 9, 2017
              Portage michigan
              Local Time:
              12:17 AM
              i could be wrong but i doubt with that Howards solid it would be happy at 6500 like he says it is with a 120 spring
              • Agree Agree x 2
              • B3422w5
                1,283
                1268
                Feb 9, 2017
                Portage michigan
                Local Time:
                12:17 AM
                it should run better than that even, really. My 9.5 to 1 360 with mild eddies runs that Mph in good air(3300 pounds) shifting at 6k
                • Agree Agree x 2
                • 70aarcuda
                  15,743
                  4279
                  Jan 16, 2005
                  las vegas
                  Local Time:
                  9:17 PM
                  I shimmed mine to a installed height of 1.80 to get them to 140ish....PRH said they were Pac 1903 springs....same spring i use on the eddy and Sm heads with flat tappet cams.....just wanted to point that out
                  • Like Like x 1
                  • Ivoryk3ys78
                    Ivoryk3ys78 Well-Known Member
                    157
                    73
                    Jul 5, 2018
                    Oregon
                    Local Time:
                    9:17 PM
                    The pistons are -13cc dish Icon 9978.
                    The fuel system.. yes that is an area that is a concern. The lines are 5/16 and so is the pickup. The fuel pump is the Carter muscle car fuel pump which on manicni shows 120gph but I looked at it on Summit it shows 25gph stock.
                    I ordered the Carter Strip 120gph pump and 3/8 line and a 3/8 pickup. Also ordered summit inline fuel pressure regulator.
                    • Like Like x 1
                    • Ivoryk3ys78
                      157
                      73
                      Jul 5, 2018
                      Oregon
                      Local Time:
                      9:17 PM
                      You are right that those are the version of the heads I have with the 120 seat pressure. I spoke with Trickflow and they said it should be fine. Howards tech said fine once and then one tech suggested shimming.
                      I decided not to shim.
                    • Ivoryk3ys78
                      157
                      73
                      Jul 5, 2018
                      Oregon
                      Local Time:
                      9:17 PM
                      Wow amazing how much you picked up with so few changes..
                    • Ivoryk3ys78
                      157
                      73
                      Jul 5, 2018
                      Oregon
                      Local Time:
                      9:17 PM
                      it is the version with the weakest springs. Trickflow said I would be okay. One call to Howards a tech said shoudl be okay. Another I was told he would feel a bit better if I shimmed.
                      I did not shim.
                    • Ivoryk3ys78
                      157
                      73
                      Jul 5, 2018
                      Oregon
                      Local Time:
                      9:17 PM
                      The spark plugs are the ones.. recommended by Trickflow NG same number they recommended. Gap is at .035.
                      • Like Like x 1
                      • Toluene56
                        Toluene56 Well-Known Member
                        912
                        687
                        Nov 9, 2009
                        reno
                        Local Time:
                        9:17 PM
                        That build is damn close spec wise to mine. Except my Howard's cam is a solid roller, but really close spec wise.
                        And I'm running a 904 with manual valve body. 4500 converter from dynamic.
                        So far, this combo has given 11.3s @119.55 at 7,000+DA.
                        I would venture to say a proper converter would wake that sucker up quite a bit.
                        Edit..
                        It probably wouldn't hurt to get more seat time and do some tuning before any hard parts get changed. Find out where it's really happy to shift. Start low and work up.
                        Mess with suspension, simple tweaks can add up.
                        • Like Like x 1
                        • Thanks! Thanks! x 1
                        • Agree Agree x 1
                        • '63GT
                          1,482
                          1525
                          Jun 9, 2018
                          Turlock, CA.
                          Local Time:
                          9:17 PM
                          Is there a track close to Reno, or do you have to tow out to Fallon?
                        • j par
                          24,692
                          12975
                          Jul 2, 2014
                          Portland Oregon
                          Local Time:
                          9:17 PM
                          I don't know about changing the fuel line or the pump if you don't see a lean spike?
                          I would like to see more passes with a little carb tuning before any more money spending..
                          • Agree Agree x 1
                          • 70aarcuda
                            15,743
                            4279
                            Jan 16, 2005
                            las vegas
                            Local Time:
                            9:17 PM
                            Fallon
                          • '63GT
                            1,482
                            1525
                            Jun 9, 2018
                            Turlock, CA.
                            Local Time:
                            9:17 PM
                            I thought so...
                          • Toluene56
                            912
                            687
                            Nov 9, 2009
                            reno
                            Local Time:
                            9:17 PM
                            yep fallon, I live in fernley so it's not too bad a drive.
                          • '63GT
                            1,482
                            1525
                            Jun 9, 2018
                            Turlock, CA.
                            Local Time:
                            9:17 PM
                            Boy, that town has grown in the last few years !!
                            Where do you go for engine work?
                          • Ivoryk3ys78
                            157
                            73
                            Jul 5, 2018
                            Oregon
                            Local Time:
                            9:17 PM
                            Yeah probably kinda jumped the gun buying those things. I figured that should eliminate it as a weak area but yeah.. unlesss seeing that with WOT testing. I may not be in a rush to install it.
                          • flyfish
                            flyfish C8H18+N2O = :-D
                            2,127
                            713
                            Apr 16, 2007
                            Indy
                            Local Time:
                            12:17 AM
                            Opinions....here are mine....
                            Carb: I'm not concerned about the size. I'm currently running low 10's with a home built "750" carb that started life as a 650dp (using a Proform main body). I do think the jetting needs looked at.
                            Fuel system: Definitely upgrade it to at least 3/8 line & better pump.
                            Converter: If you want a fast drag car you NEED to spend money on a GOOD converter. I personally run a PTC 8". Works fine on the street and strip.
                            Last, but not least...and probably not what you want to hear....I would pull that cast Eagle crank while it is still in 1 piece and put in a forged crank (the Scat cast crank seems to be fine if you want to be cheap....but I don't think this is a good place to be cheap...just my opinion). I have seen too many horror stories of cast Eagle cranks braking under modest power. Eagle Forged cranks were fine, I actually ran one for quite a few years.
                            Your car should be about a second faster, just looking at what you have. Best of luck tuning, hopefully it will come around.
                            • Like Like x 2
                            • Agree Agree x 2
