1. barbee6043
    barbee6043 barbee 6043 FABO Gold Member
    12,868
    5473
    Jul 20, 2008
    Shepherd, Texas ( SE Tx)
    Local Time:
    12:48 AM
    I admit I have never had this problem before, but this 64 B body ply. post car has sat outside here in sorta dryish Texas for the last 40 years. I gotthe vent wind open, the window meanism is rusted and can;t rill down the glass. Doors are unlocked, I can move the inside door handle,, the outside handle seems to be working. Could not budge the door.
    Since it is an Early B body, the floors are pretty much history, especially since it came new with the rubber floor covering!
    So I jacked it up, front end still sitting on the car trailer, and cut out a little more rsted floor, and crawled into the beast. I had already taken off the 4 nuts holding down the front bench, and moved it forward. Got the door panel off, and the inside door mecansim is no dobt rusted froze.
    Soaked it all with rust penetrant, day later still froze. I retired the acetelyn torch 4 years ago with it was woreout and both tanks were empty.
    Question is will a map gas torch get it hot enough to free it up?
    Any other ideas? Thanks
  2. famous bob
    famous bob mopar misfit
    17,504
    6977
    Aug 14, 2011
    okla
    Local Time:
    12:48 AM
    Have you tried P B blaster , has worked within 30 minutes on rust for me .
    • Agree Agree x 1
    • barbee6043
      12,868
      5473
      Jul 20, 2008
      Local Time:
      12:48 AM
      ^^^PB Blaster and Liquid wrench!! also. Yankees have something they call Kroil they swear by but it must be a Northern commodity!!
    • Syleng1
      Syleng1 Karma is real and Life is short... FABO Gold Member
      1,864
      1437
      Jul 5, 2005
      North Franklin, CT
      Local Time:
      1:48 AM
      Kroil is like in a orange 3in1 oil type container used by high end machine shops like $20 a small can.
      It is now being sold locally here in the North east at "REAL" hardware stores.
      The stuff is excellent but I've yet to use it as a penetrant only as machine oil for threading and cutting.
    • 65 Dartman
      65 Dartman FABO Gold Member FABO Gold Member
      11,627
      3207
      Sep 24, 2006
      Strasburg, VA
      Local Time:
      1:48 AM
      map gas used with oxygen will certainly heat metal cherry red. Years ago when I couldn’t afford oxyacetylene so next best was the Map with a small tank of O2. Has done the job over the years for me.
    • lilfontleroy
      lilfontleroy annoyinglilLeroy FABO Gold Member
      2,685
      2428
      Nov 20, 2017
      Intercourse
      Local Time:
      12:48 AM
      you'll probably get somewhere with some heat but I wouldn't think you need to get it red hot... PB, heat and repeat. Also, a punch and a hammer if you can get it in there just to shake it up
      • Agree Agree x 1
      • sireland67
        sireland67 FABO Gold Member FABO Gold Member
        9,287
        3475
        Oct 27, 2010
        WV
        Local Time:
        1:48 AM
        You can buy Kroil from Amazon, you will throw PB and Liquid wrench in trash after using the Kroil.
        Be warned, it stinks bad. I think it is bottled skunk piss.
      • barbee6043
        12,868
        5473
        Jul 20, 2008
        Local Time:
        12:48 AM
        Yes, I did the hammer/punch deal also.
        I will go to Amazon and order some Kroil. With all the bad rust in New England, I figure those guys understand what works!
        I drug home a 77 Volare wagon from the dry Tx Hill Country coue years back, got it for the perfect grill.$500 complete rust free n running wagon. I took me quite a while to get the floors open, latches worked, but..they were stuck at the door weather striping, like super glued together!!!! lo
        • Like Like x 1
        • Murray
          Murray FABO Gold Member FABO Gold Member
          1,944
          1310
          Apr 19, 2010
          San Jose, California
          Local Time:
          10:48 PM
          Did you unlock the door?
          • Like Like x 1
          • famous bob
            17,504
            6977
            Aug 14, 2011
            okla
            Local Time:
            12:48 AM
            We used kroll when I worked for the city of Tulsa , it never showed me anything special , except expensive , always thot p b blaster worked faster -----------------??
          • barbee6043
            12,868
            5473
            Jul 20, 2008
            Local Time:
            12:48 AM
            YES.
          • mopar head
            mopar head Well-Known Member
            2,867
            587
            Oct 21, 2008
            Right here, can`t you see me?
            Local Time:
            1:48 AM
            You sure it ain`t sagging jambing the doors tight?
          • barbee6043
            12,868
            5473
            Jul 20, 2008
            Local Time:
            12:48 AM
            I have gently pried on the doors thinking it could be that, but have not budged them. I soaked them with penetrant yesterday, hosed it out today best I could, I will get back at it tomorrow if the rain lets up.
            I have had these old Mopars with most if the floors out and the doors still shut fine.
            Yesterday I could not move the inside door latch mechanism with a punch and hammer! With the handle opening the inside latch to open.
            You should see this old 72 yr old 6 ft tall, woreout man, climb in from underneath thru where the rear floor pan used to be. Yes tunnel is still there! lol
            • Like Like x 2
            • mopar head
              2,867
              587
              Oct 21, 2008
              Local Time:
              1:48 AM
              Well you said the front was up on the trailer , If it`s not too much trouble roll it off on flat ground and try. But. If you say it`s rusted...
            • Tooljunkie
              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
              15,662
              15225
              Jul 22, 2017
              Manitoba
              Local Time:
              12:48 AM
              I had to use prybar and a block of wood and pried the doors open on my dart.
              Never thought about it until now, but my porta power would have pushed the drivers door open after i got passenger side open.
              Prybar to open trunk too.
              • Thanks! Thanks! x 1
              • barbee6043
                12,868
                5473
                Jul 20, 2008
                Local Time:
                12:48 AM
                Rained all day and night Back at it this morning.
                • Like Like x 1
                • diymirage
                  diymirage HP@idle > hondaHP@redline
                  20,310
                  14683
                  Oct 12, 2012
                  michigan
                  Local Time:
                  1:48 AM
                  i would try with it sitting as flat as possible to get a jack right under the door and jack it up
                  see what that does
                • barbee6043
                  12,868
                  5473
                  Jul 20, 2008
                  Local Time:
                  12:48 AM
                  Took the air cheisel and gave her some good knocks, finally the mechanism got loose and door popped right open. LIke I figured rusted and not moving even with 3 days of penetrant and beating it with the long punch and good hammer!
                  Now for the window, its rusted shut too!!!!!! lol, and the other door!!!
                  The floors have rusted out, but I had 2 of these back about '95 or 6 and they were in same shape!!! Sitting out in Tx does not bother the frames!!!
                  Like said, last time this sucker was on the highway was '80!!!!
                  • Like Like x 3
                  • mopar head
                    2,867
                    587
                    Oct 21, 2008
                    Local Time:
                    1:48 AM
                    Damn, was this thing a gulf coast salt water hurricane flood car? lol
                  • barbee6043
                    12,868
                    5473
                    Jul 20, 2008
                    Local Time:
                    12:48 AM
                    No not really, just has sat outside since '80, thats 40 years! If it was an hour further West it would have done better though. Just humidity.
                    I have to out out and use the air cheisel on the other door now!!!!
                    Body is pretty solid except floors and some on cowl as all early b bodies are.
                    I had a twin to it I built back bout '95 with a 440 4 speed It was a slant 3 on tree car also. I'm getting too old for this!
                    • Like Like x 1
                    • Murray
                      1,944
                      1310
                      Apr 19, 2010
                      Local Time:
                      10:48 PM
                      Remind me to never buy a used car from Texas.
                    • barbee6043
                      12,868
                      5473
                      Jul 20, 2008
                      Local Time:
                      12:48 AM
                      Ca. coast cars? lol Lots of dry air in Tx just not in Huntsville. All cars rust somewhere early B cars rusted in floors and a few other places just like all models! Not sure why the door mchanisms were stuck so bad, Had to be just enough rust. Maybe fumes from th hiuge Tx rat turds! LOL
                      Other than floors, small place on cowl pretty darn solid old car. I have built many 68-70 Runners and Chargers 20 yrs ago a lot rustier!!!
                    • Al Dusty73
                      Al Dusty73 Member
                      17
                      0
                      Oct 4, 2020
                      California
                      Local Time:
                      10:48 PM
                      Help. My door on my 73 duster inst opening. The door is unlocked. The button goes down on the exterior and i can see the parts moving on the inside but the latch wont budge. Help.
                    • barbee6043
                      12,868
                      5473
                      Jul 20, 2008
                      Local Time:
                      12:48 AM
                      Mine were rusted shut. What I all the mechanism that keeps the door shut. I had soaked with penetrant several days and hit it hard with long punch and big hamer! I finlly gotit working with th air chesel an somegood pounding. Once free it moves and works great!!
                      The second dorr was same xcepththe lock was also rusted shut and almost catching th gear to lock it. It as just up against the mechanism and that mechanism was also rusted shut. The window regulators are also rusted and not moving!!!
                      This is a Tx car, NOT on the coast and sat with all windows up!! But had sat sine 1980!!!! LOL
                      I probably would have never got it unstuck without that air chisel, my torch was down and that could have easily got it loose. But..
                    • Al Dusty73
                      Al Dusty73 Member
                      17
                      0
                      Oct 4, 2020
                      California
                      Local Time:
                      10:48 PM
                      I'll try more penetrant. Im confused because I use that door every day. Somewhere along the lines a previous owner changed the driver side lock and lost the key. This is also my first car ever so i really dont know what im doing. Thanks for the tips!
