Dennis Gerard
I have 2 stuck valves on a 71 318 engine , any suggestion on free-ing them.
still on engineAre the heads on or off the motor?
When I was helping Matt last year, we had like a 59 Ford truck come in with a skip. It had a valve stuck open and I did exactly as you described and freed it up and got it running good. We were ready to pull the head(s) off if needed but we didn't have to.PB Blaster, small hammer, big flat tip screw driver or small prybar.
Time to get the gooey gas out of the tank and lines.push rods bent , valves look ok
Just be sure that the piston is not right under itPB Blaster, small hammer, big flat tip screw driver or small prybar.
new working off soda bottles, but read the above post. if'fixed.How old is the fuel?
