jhaas63
I want to take the backseat out of dart so I can remove the back decklid cardboard piece. I can easily lift the top part of the back seat but it is not slipping out. Is there a trick?
Move the front seat full forward. Drop a knee in the rear floor a pull backward on the bottom of the seat and lift it up out of the hook. Sounds easier than it is sometimes. If it goes back far enough it will come up.
To lift the seat back a lot higher than nessesary to get off those hooks can bust the headlinner in some models. Be careful.
The build sheet should be under the rear seat bottom between the springs and the knapsak material. That is as long as the rats didn't get it first.
