yes you can, take the mirror off and you will see a plate that is triangular in shape with a hole in the center that the ball is exposed from. Remove that plate (three screws) put it on the anvil part of your bench vise and hit it a few times to put a mild curve to it and put it back together. Should be tight after that!
