Stupid question
smythge
65 with a BIG BLOCK
Where on the block do I install a mechanical oil pressure line? I am sure it's one of the holes in the back on the block near the transmission, but want to be sure.
Theres 1 little hole next to the distibutor on top of the block. This is the hole you will use to plum oil guages.
(P.S., thats not a stupid question)
Rumblefish I belive, he's running a big block, You are right for the small block though! Both ports at the back of the big block are pressure ports!
Thanks, he didn't say what engine he had.
Bad info in, bad ino out.
