Suction bleeder help
player1up
orlando FL
Ok so I bought a suction bleeder and am trying to bleed my brakes after a wheel cyl replacement, but the stupid thing is sucking air in around the bleeder valve threads instead of fluid through the wheel cyl. How do I fix that? teflon tape? bailing wire?
Oh, and why would the new bleeder screw be a different size than the one on my old wheel cyl?
I bought a mityvac 20 years ago for the same purpose.
Never could get it to work better than a long tube from the bleeder down into a jar with some fluid already in it.
Well crap, I thought I was doing something wrong.... I even tried just barely cracking the screw thinking that the threads would seal
Wont the cup/hose method have the same problem with air getting in around the threads??
DOH! :angry7:
Hey, anyone want to buy a vacuum bleeder with gauge and cup? :toothy10: used only once! NEARLY BRAND NEW! :lol: :lol:
Same exact problem here too.....
I ended up using it just to change the fluid.....made sure all the fluid was flushed and then had an assistant pump for me while I wrenched.
DOH! :angry7:
Just crack the screw a 1/2 turn, make sure the hose is below the fluid level, and stroke the brake pedal by hand, waiting for it to return to neutral.
If it's not a new MC, don't go full travel, you'll trash the o-rings by going over the step that gets worn in the MC bore.
Check the reservoir to make sure you don't suck air.
