Barely used 8,000 RPM Sunpro Super Tach Retro, #SST802R.
Works perfectly, just removed from car on 10/13/13.
You will not find a better working, looking used tach, so save some dollars and buy used!
$100, includes domestic shipping to lower 48 states only.
Located in Beresford, SD 57004
Description/details:
60° Lighting
Blue-Line Styling with red shift pointer
Internal settings for 1,2,3,4,5,6,8 and 10 cylinder engines
All metal tach housing with removable chrome metal cup
Comes with steering column mount bracket only
Vibration Proof, air core meter design
Straight from 70's styling, the Sunpro Tachometer was an icon in speed parts circles. Here's your chance to own a legendary Sun Super Tach reproduced with modern electronics inside and retro looks outside. This tachometer will put the finishing touch on any hot rod project.
60° Lighting
