1. Glenguy
    Glenguy Well-Known Member
    87
    76
    Oct 12, 2019
    Alberta, Canada
    Local Time:
    2:23 PM
    I found a car with this slant 6 engine. According to what it says on the air cleaner, is there something special about this engine in terms of horse power?
  2. RustyRatRod
    RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
    65,818
    39124
    Jun 7, 2010
    Georgia
    Local Time:
    5:23 PM
    Marketing.
    • Agree Agree x 3
    • Glenguy
      87
      76
      Oct 12, 2019
      Alberta, Canada
      Local Time:
      2:23 PM
      Thanks, I'm might want to buy that one if the price is reasonable.
    • halfafish
      halfafish Damn those rabbits, and their holes! FABO Gold Member
      1,894
      1669
      Aug 14, 2016
      SW Washington
      Local Time:
      2:23 PM
      Pull the air cleaner off and see what kind of a carb it has - one barrel or two barrel? A one barrel is plain-jane but will work fine until the cockroaches inherit the earth. A two barrel is a nice upgrade. Some photos of the rest of the intake from the other side will help evaluate it.
      • Like Like x 2
      • RustyRatRod
        65,818
        39124
        Jun 7, 2010
        Georgia
        Local Time:
        5:23 PM
        It's a one barrel.
      • halfafish
        1,894
        1669
        Aug 14, 2016
        SW Washington
        Local Time:
        2:23 PM
        I'd tend to agree, but I've seen two versions where a two-barrel was migrated onto a one-barrel setup. Looked the same from the angle in the photo but had been adapted below the air cleaner.
        • Like Like x 1
        • Glenguy
          87
          76
          Oct 12, 2019
          Alberta, Canada
          Local Time:
          2:23 PM
          Thanks, I kinda sorta thought it might be two barrel. I should have taken off the air cleaner to have a look. No wonder my dad's big 'ol '65 Dodge moved so slow with that one barrel carb! lol
        • RustyRatRod
          65,818
          39124
          Jun 7, 2010
          Georgia
          Local Time:
          5:23 PM
          Just remember "Super 225" and "Super Six" are not the same. The Super Six was the name for the factory 2 barrel engine. What you have is a one barrel. Here's how I know. If it had the two barrel flange on the intake, you could see the edge of the flange, because that is a small diameter air cleaner. You can see no intake flange, so it's a one barrel.
          • Agree Agree x 2
          • Like Like x 1
          • RustyRatRod
            65,818
            39124
            Jun 7, 2010
            Georgia
            Local Time:
            5:23 PM
            See how close the intake flange edge is to the stud hole that holds the intake to the exhaust manifold? Now look in your picture. If it was a two barrel, the edge of the intake flange would be clearly seen. It's not. Still a darn fine engine either way.
            • Like Like x 2
            • Agree Agree x 1
            • Glenguy
              87
              76
              Oct 12, 2019
              Alberta, Canada
              Local Time:
              2:23 PM
              Thanks, RustyRatRod, you know your stuff! I still might try to buy that engine. It's a Canadian made '65 Valiant ragtop with a Dart front clip. Unfortunately the body is totally roached out everywhere with rust, and I mean swiss cheese and potato chips all over the place. The engine oozes with cool factor. Not sure where I would keep the engine if I bought it, considering that I don't even have a garage, but I sure want it.
            • Slantsix64
              Slantsix64 Well-Known Member
              2,794
              1107
              May 11, 2014
              SGV
              Local Time:
              4:23 PM
              Its a one barrel look at the choke. Super six two barrel have a different choke orientation
            • /sixchall
              /sixchall Well-Known Member
              219
              129
              Jan 19, 2017
              Riverside ca.
              Local Time:
              2:23 PM
              I’m going to agree with the rest of the enthusiasts here. The Super 225 air cleaner decal you’ll find on the Plymouth Slant6 single bbl engines. The Charger 225 decal will be on the Dodge single bbl engines. I have the Super Six modification on my own Slant6 engine. I’m running the Carter BBD 2bbl, that I pulled from a early 70’s 318. My air cleaner is an after market chrome 14”x3” with 2 bbl adapter. The factory 2 bbl air cleaner has the belled snorkel for the Cold Air System.
            • slantsixdan
              slantsixdan =..=
              6,741
              1917
              Jan 7, 2007
              Vancouver BC
              Local Time:
              2:23 PM
            • /sixchall
              219
              129
              Jan 19, 2017
              Riverside ca.
              Local Time:
              2:23 PM
              Great info here Dan.
