my68barracuda
Intake Manifold, Carb and Air Cleaner Housing
2017 5 May Super Six Package
Intake Manifold: this is the OE intake from the '83 D150,, this is the die cast two piece intake, nice light weight part, weighs 6.5 lbs. I have photographed two areas where the intake had a weld repair on the seam,, I remember it was not long after dad bought the truck new that the truck developed a rough idle,, he took it in for service, there at the local friendly Dodge Dealer they found and welded the leaking seam areas. That was 33 years ago,, never had another issue with the seams leaking.
Also note, I used this intake on the 68 Barracuda with a set of long tube Hooker Headers, to get the intake flanges to fit within the Hooker header flanges I had to trim the top side of the flanges. They are now about the size of a typical slant six intake flange, there is plenty of land for the triangle washer to sit. The manifold includes an EGR port cover plate.
Carb: this is the OE BBD 2 BBL carb, note that it has the original carb series tag on it. Throttle shafts are tight, I put a rebuild kit on it and ran this cab on the 68 Barracuda, starts and runs fine.
Air Cleaner Housing: this is the OE housing from the 83 D150, note that with the housing in the 'stock' position the air intake snout will set across the valve cover, as that is how it was done on trucks,, if someone wanted to use this air cleaner housing in a car,, one could: a) position the air intake snout across the valve cover like it is in the trucks or b) swing the housing around so the air inlet points towards the passenger side, I do not believe there is anything that clocks the air cleaner housing to the carb.
Also note: the 83 was a lean burn unit with the ECU mounted to the air cleaner. The lean burn ecu is long gone, so there are two small openings that can be left as is or easily closed with a piece of sheet metal.
300.00 + shipping for the Super Six Package
