superstock springs
racyroy1
graham, wa.
Where is the best site to buy superstock springs for a 71 scamp I found them on mancini racing for about 210$
racy
do they sit above stock and if so by how much, I want to drive my 71 but it has sagging springs, and if it sits above stock i'm not wanting that and if it does sit above stock then where is a good place get a set of stocks. The reason I ask is I could search all day, or ask you guys and cut out the middle man so to speak.
thanks
racy
If you have stock slant 6 springs that are saggy be prepared for it to sit a good 4" higher in the rear and lop sided.
I gained about 3" over my saggy stockers. I didnt bother to change the shocks when I went to super stock springs. This is how it sits with the super stockers. I got mine from Mancini also.
thanks guys, 3 to 4 inches too high and i'm a guessin high on the right side huh? and if not the stockers where can I pick up a new set of stock springs.
did ya find out what was wrong with yer motor adam??
