[WANTED] Sure grip cone style case
HR5058
Eldridge, Iowa
All, I am looking for just the two case halves for a cone style sure grip. Mine are damaged but rest is in good shape. Thanks Chuck
...........If urs is damaged from the pin slopping in the case a good welder buddy can fix it....hopefully the spiders r not welded to the pin...................kim...
Thanks Kim. The pin broke and it wore pretty good on both ends and halves of case. I will take it to a weld shop and see if they can do it. They rest is in pretty good shape. Thanks Chuck
