swaybar hardware
RedFish
I'm only 4 bits away from adding the stock front swaybar on a my 67.
The 4 bolts that attach those forward mounts to the K frame are ?X? X ?
Bolts inserted top down or bottom up ?
What type nuts did they use ?
Any washers there ?
Better still does anyone have the OEM hardware available ?
Thanks FABO
I know the swaybar links MUST go from bottom to top on my 73 duster with moog parts.
Its not the end links I question but the forward mounts. Totally differnt from your 73. Thanks tho :)
