demon ed
Need a new switch my new ignition switch did not come with it and its burned.
1971 340 demon 4sp
1971 340 demon 4sp
All the wiring is in bad shape so I am replacing all of it main harness headlight to taillights underhood etc. The new harness didnt come with it .That is the key in warning buzzer switch. I found a new one on eBay for mine. The question is what caused it to melt down? The buzzer is in the horn relay and is supplied 12 volts looking for a ground thru the switch to the driver door switch on my 71 Demon. I also replaced the molex connector on the ignition switch with a weather pack connector due to the new wiring harness in the car and the new ignition switch making poor connection with the new parts.
1971 340 demon 4spView attachment 1715122016
