T5 transmission to Slant Six OD bell housing adapter
Slant 6 Engines
  1. my68barracuda
    my68barracuda Well-Known Member
    1,678
    1377
    Dec 6, 2009
    Indianapolis IN
    Local Time:
    3:58 AM
    A long time slant six racer / builder that posts at .org is putting together a plan to manufacture a one time run of adapters to fit a Ford T5 manual tranny to a slant six bell housing. To gauge interest and the quantity that may be sold (that will have an impact on price) he has started this thread....the parts are not for sale yet, there are no photos of the parts or pricing available, that is why this thread is not in the for sale section,,,,,
    T5 / OD Bellhousing Adapter Plates For Sale! (Gauging Interest) - Slant Six Forum
    The thread below details mating a T5 to a slant six bell housing. It has been done before, with one off custom conversions and a previous group buy project.
    The Definitive All of your questions answered T5 T-5 5 speed To Slant 6 Transmission Swap Guide. - Slant Six Forum
    • Thanks! Thanks! x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      70,700
      45570
      Jun 7, 2010
      Georgia
      Local Time:
      3:58 AM
      Thanks John!
      • Agree Agree x 1
      • Slantsix64
        Slantsix64 Well-Known Member
        2,988
        1216
        May 11, 2014
        SGV
        Local Time:
        2:58 AM
        That's so badass, he should make the cross memeber as well.
      • RustyRatRod
        70,700
        45570
        Jun 7, 2010
        Georgia
        Local Time:
        3:58 AM
        I have a T5 and a slant six three speed sittin side by side and I've never even thought about it. lol
        • Like Like x 1
        • jbcalhoun
          jbcalhoun Member
          16
          18
          May 8, 2013
          Midland, TX
          Local Time:
          2:58 AM
          I adapted a T5 to my slant six but was never really happy with my work. I contracted Quick Time to engineer me a new blow proof bell. By the way they can refurbish your stock bellhousing so it can accept a Ford T5.
          Any way, I paid all the costs of having it engineered so now they have it on file and the cost for a new Quick Time SFI approved housing is like half the cost I paid.
          It works really well and I love the Ford T5 in my 63 Boosted EFI Dart. What a fun drive it is now. Love the overdrive!
          • Slantsix64
            2,988
            1216
            May 11, 2014
            SGV
            Local Time:
            2:58 AM
            Well get to it! :popcorn: lol
          • RustyRatRod
            70,700
            45570
            Jun 7, 2010
            Georgia
            Local Time:
            3:58 AM
            Does the T5 fit well in the early A transmission tunnel? Any mods needed?
          • my68barracuda
            1,678
            1377
            Dec 6, 2009
            Indianapolis IN
            Local Time:
            3:58 AM
            Are you saying that QT will make a blow proof bell that bolts to a slant?
            Is it for the 13O tooth FW?
            tell me more!
            • Agree Agree x 1
            • jbcalhoun
              jbcalhoun Member
              16
              18
              May 8, 2013
              Midland, TX
              Local Time:
              2:58 AM
              No. The transmission tunnel is too small and needs modification. Not a real big deal if you have any fabrication skills and welding skills. I chose not to use aluminum as I have done on the many race cars I've built in my lifetime as I wanted a Car for cruising with my Wife and didn't want any leaks. LOL I'm 70 years old and been there and done that on about anything dealing with cars.
              • Like Like x 2
              • jbcalhoun
                jbcalhoun Member
                16
                18
                May 8, 2013
                Midland, TX
                Local Time:
                2:58 AM
                Yes, their Bell will bolt directly to the slant six. I used the stock flywheel, the stock (although new) pressure plate and used a new clutch disc from a Ford 2.3 Turbocharged Thunderbird. The clutch disc measures the same thickness as the stock slant six disc and the 2.3 has the correct spline for the input shaft of the T5 I used. The clutch disc for the 2.3 is 1/4" smaller in diameter which hurts nothing. The 2.3 produced around 190 horse power which will handle much of anything the slant six can throw at it. Stock disc have been known to handle in excess of 400 horse power with no slipping. I machined my pilot bushing out of oil impregnated bronze. Any machine shop can do this if you don't have a lathe. I don't know if it was my initial mismeasurement or not but I had to take I believe it was 190 thousandths off the snout of the T5 so it wouldn't hit the clutch disc. I also used a Tilton Hydraulic throw out bearing which made the installation easy. A hydraulic clutch master cylinder can easily be bolted to the firewall and line up with the clutch pedal. Tilton does recommend you use a diaphram type pressure plate but I couldn't find one so used the Long style pressure plate that the stock slant six uses with no ill effects.
                That's it in a nutshell.
                • my68barracuda
                  1,678
                  1377
                  Dec 6, 2009
                  Indianapolis IN
                  Local Time:
                  3:58 AM
                  At one point I time QT had a blow proof bell that would bolt up to a slant, but that bell was discontinued and is no longer available. Is that the QT housing that you are mentioning?
                • jbcalhoun
                  jbcalhoun Member
                  16
                  18
                  May 8, 2013
                  Midland, TX
                  Local Time:
                  2:58 AM
                  Just so you know I also used the stock 3 speed transmission mount which required very little modifications. Of course your driveshaft will have to be made to or modified to fit. I used a Ford rear end which I narrowed myself and after careful measurement found an internet site which built me a totally new driveshaft with the proper transmission and the proper rear end fixtures that was about $300 cheaper than having a driveshaft built locally.
                  • jbcalhoun
                    jbcalhoun Member
                    16
                    18
                    May 8, 2013
                    Midland, TX
                    Local Time:
                    2:58 AM
                    Quick Time did build a bellhousing that bolted directly to the slant six but used a Mopar 4 speed transmission. I had mine built last year which should still be available. You can talk to Ron ( I think was his name) at 1-866-464-6553 if you want to bypass Holley which now either owns or represents Quick Time.
                    • jbcalhoun
                      jbcalhoun Member
                      16
                      18
                      May 8, 2013
                      Midland, TX
                      Local Time:
                      2:58 AM
                      The number may not be a direct line to QT as I remember now that I had the cell number for the direct line to QT. The number I gave may actually be to Holley. I must have deleted the cell number I had as I can't find it in my phone.
                      • jbcalhoun
                        jbcalhoun Member
                        16
                        18
                        May 8, 2013
                        Midland, TX
                        Local Time:
                        2:58 AM
                        The bellhousing QT made for me also had the adapter rings so It would accept two other Ford transmissions, although I can't remember which transmissions they were. I'd have to look and see if I had the paperwork that came with the housing.
                        • my68barracuda
                          1,678
                          1377
                          Dec 6, 2009
                          Indianapolis IN
                          Local Time:
                          3:58 AM
                          Thanks, if you can, concerning the QT bell that will bolt to a slant, can you get to me:
                          A contact name at QT
                          A date or time period that housing was made
                          A purchase number, part number, something that would trace back to the engineering data.
                          Thanks again.
                          • Like Like x 1
                          • jbcalhoun
                            jbcalhoun Member
                            16
                            18
                            May 8, 2013
                            Midland, TX
                            Local Time:
                            2:58 AM
                            I spent a full hour on hold with Holley today and never a peep on their end. So tried another way by emailing them for duplicate information on my order for the Quick Time housing. Hopefully this will work.
                            I did find the adapter rings in their original packaging but no documents were found. Did some spring cleaning about a month ago and the box it cam in was thrown away.
                            Last chance is maybe a number is stamped on the housing but I have all my lifts tied up and will be a couple of days before one is cleared.
                            Keep your fingers crossed as I'm not one to easily give up!
                            • my68barracuda
                              1,678
                              1377
                              Dec 6, 2009
                              Indianapolis IN
                              Local Time:
                              3:58 AM
                              Thanks
                              • Agree Agree x 1
                              • jbcalhoun
                                jbcalhoun Member
                                16
                                18
                                May 8, 2013
                                Midland, TX
                                Local Time:
                                2:58 AM
                                Well this may be lucky news! There is a number engraved right under the SFI sticker. It reads B195934. No other markings were located.
                                I'd be happy to text you some pictures. I don't want to go to the trouble of posting them, however you are welcome to do so.
                                • my68barracuda
                                  1,678
                                  1377
                                  Dec 6, 2009
                                  Indianapolis IN
                                  Local Time:
                                  3:58 AM
                                  Thanks, I sent you a pm with a phone number you can text the photos to
                                • Slantsix64
                                  2,988
                                  1216
                                  May 11, 2014
                                  SGV
                                  Local Time:
                                  2:58 AM
                                  They should also make the bell crank, and the clutch fork. This is something I'm thinking and of doing.
                                • dart19666
                                  dart19666 FABO Gold Member FABO Gold Member
                                  566
                                  315
                                  Jul 28, 2014
                                  Collierville, TN
                                  Local Time:
                                  12:58 AM
                                  I like the pic you have.
                                • Slantsix64
                                  2,988
                                  1216
                                  May 11, 2014
                                  SGV
                                  Local Time:
                                  2:58 AM
                                  Haha thanks
                                • Fredsgarage
                                  Fredsgarage 1964 Dart Convertible w/4 speed
                                  44
                                  26
                                  Apr 24, 2019
                                  Des Peres, Missouri
                                  Local Time:
                                  12:58 AM
                                  Im jumping on the back of this thread as I am going to put a T5 behind my Slant in my 64 Dart. I have purchased the GillWelding T5 adapter and also found a Aluminum A833OD bellhousing. I need to employ a Hydraulic TO Bearing and that's where I ended.
                                  I remember from last year that there was a more comprehensive thread on this?
                                  Am I right?
                                • vitamindart
                                  vitamindart Well-Known Member
                                  1,291
                                  371
                                  Jun 11, 2010
                                  Vernon,Wisconsin
                                  Local Time:
                                  2:58 AM
                                  fred, i think the threads you are looking for are linked on the first post. pretty sure all those threads are over on .org
