Tachometer reads too high
66cudaman
Active Member
Lakeside, AZ
This is surely an old question but as a new member is new to me. I have a '66 Barracuda with a tachometer. It has been refurbished, all wiring checked and properly connected, etc. When running the tach swings all the way over to the highest reading and stays buried there. What needs to be done? Thanks.
jwcuda1
jwcuda1
I'm not too familiar with the factory tachs, is there a switch on the back of it maybe to switch from 6 to 8 cylinder??? Is it wired to the negative terminal on the coil???
Just thinking out loud for ya.
jwcuda1
Turn down the idle screw..................LOL
Sorry, had to say it :banghead:
What are you running for an ignition system?
It's possible that the rebuilder calibrated it for 6 instead of V8
