TCI 727 Torqueflite race trans (pn. 890-112000)
Transmission and Drivetrain Tech
  1. Zachow Duster
    Zachow Duster 72 Duster 440 (550+ HP)
    4
    2
    Feb 27, 2021
    Munnsville, NY
    Local Time:
    3:01 AM
    I just purchased this TCI trans (pn. 890-112000)
    Rev Man valve body, 4.2 lever, steel planetaries
    5 disk sets etc
    anyone out there unhappy with this unit?
    anything I should be aware of?
    I want to put in a 5000 s/s convertor
    for a couple hundred miles a year street
    and occasional drags. Motor is 550 HP 440
    in a 3100# 72 Duster with 456 gears
    • Like Like x 1
    • Biff
      Biff Cheep not easy
      7,405
      15766
      Jan 30, 2017
      Canada
      Local Time:
      12:01 AM
      5000 stall is high for the street . My opinion only .
    • Demonx2
      Demonx2 FABO Gold Member FABO Gold Member
      310
      528
      Dec 10, 2019
      Michigan
      Local Time:
      3:01 AM
      NOW you tell me!! I don't have 550hp but I do have an 8" conv with roughly that stall speed behind my 408. My planned usage is about the same as @Zachow Duster. We'll find out how it works in a few months!
    • CudaFactHackJob
      CudaFactHackJob FABO Gold Member FABO Gold Member
      1,651
      623
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      2:01 AM
      5k is even high for the strip; unless you're shift completes at over 5k. That's okay, just shift at 8k and you'll be just fine.
    • famous bob
      famous bob mopar misfit
      19,530
      8592
      Aug 14, 2011
      okla
      Local Time:
      2:01 AM
      might work even better at 10,000 !
    • CudaFactHackJob
      1,651
      623
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      2:01 AM
      I rebuilt a C4 for a guy one time. He called and said it didn't work; wouldn't even move. He said he revved it and nothing. Had a new torque converter he bought off a buddy... So he brings the trans back along with the converter. I said where's the converter? He picks it up out of his trunk with one hand; like an 8" donut...5k stall...His old worn out 302 two barrel couldn't even rev high enough to hit stall.
      • Thanks! Thanks! x 1
      • Disagree Disagree x 1
      • forphorty
        forphorty Well-Known Member
        744
        345
        Jan 19, 2006
        Local Time:
        2:01 AM
        If his car wouldn't move at all , it wasn't because it was 5000 stall. It was either broken/defective or he was low on fluid.
        • Agree Agree x 2
        • CudaFactHackJob
          1,651
          623
          Mar 17, 2016
          Hemet, Ca.
          Local Time:
          2:01 AM
          What rpm do you think a 5k stall should engage?
        • LO23M8B
          LO23M8B Well-Known Member
          865
          414
          Jan 30, 2019
          Michigan
          Local Time:
          12:01 AM
          5k convertor is fine on the street just don't idle in gear for a long time. Used 5000 and 5500 on the street for over 45 years and 0 problems. Just don't overheat, use a extra cooler, keep the fluid changed and a trans temp gauge. You'll love it! ps do not do burn outs in first gear!!!!
          • Like Like x 1
          • Agree Agree x 1
          • fishmens67
            fishmens67 Well-Known Member
            9,888
            8399
            Nov 10, 2012
            idaho
            Local Time:
            2:01 AM
            5000 stall on the street is fine for the right combo.
            for a 440 with 4.56 gears it's overkill. I'd cut it back 500- 800 rpm. 4200 stall would be a better bet.
            • Like Like x 1
            • Zachow Duster
              4
              2
              Feb 27, 2021
              Munnsville, NY
              Local Time:
              3:01 AM
              Thanks for the insight
            • forphorty
              744
              345
              Jan 19, 2006
              Local Time:
              2:01 AM
              My 4500 stall Dynamic will creep forward at a 900 rpm idle on level ground.
              • Agree Agree x 3
              • fishmens67
                9,888
                8399
                Nov 10, 2012
                idaho
                Local Time:
                2:01 AM
                The OP hasn't offered enough info on his 550 HP 440.
                5000 is overkill and not needed. imo BTDT. lol
                • Agree Agree x 1
                • transman
                  transman Well-Known Member
                  832
                  280
                  Jun 17, 2007
                  Western Canada
                  Local Time:
                  12:01 AM
                  Get a converter BUILT TO YOUR SPECIFICATIONS. Just because my Whiz-Bang 5000 works in my car, doesn't mean it will work worth a damn in your car. Contact one of the converter builders that have been mentioned many times on this board and get one for your specific application. An even better idea would be to contact 2 or 3 builders and see what they recommend for your use. Keep in mind too, that quality doesn't come cheap. Over the years, I've seen that you only get what you pay for.
                  • Like Like x 1
                  • flyfish
                    flyfish C8H18+N2O = :-D
                    2,284
                    868
                    Apr 16, 2007
                    Indy
                    Local Time:
                    3:01 AM
                    Dear lord there is a lot of miss-information on this thread from folks that have probably never had an 8" converter.
                    Yes, you can drive a "5k" converter on the street...and NO, it is not too much if you have a good converter and a properly setup car.
                    For what its worth: My street/strip Barracuda has an 8" converter that stalls a little over 5k behind my 408....it pushes my car to low 10's in the 1/4.....AND it can drive down the street at 2000-2500RPM without issues. I drive my car all over town on the weekends that I'm not racing....heck, ~ 50% of the time I drive to the race track, compete in an event clicking off 6.4x's in the 1/8 mile and then drive home!
                    I guess the real question is, what is street-able to you? This varies from person to person.
                    • Agree Agree x 1
                    • flyfish
                      2,284
                      868
                      Apr 16, 2007
                      Indy
                      Local Time:
                      3:01 AM
                      You will be fine, don't worry about it.
                    • flyfish
                      2,284
                      868
                      Apr 16, 2007
                      Indy
                      Local Time:
                      3:01 AM
                      5k too high for the strip....WHAT?!?! Have you been to a drag strip? Almost every fast (or relativly fast) NA car I know at the strip has at LEAST a 4500 stall (most are 5000-5500)
                      There must have been something else wrong with the trans. "rev high enough to hit stall"....I don't think you have any idea how a torque converter works.
                      My 5k converter makes my car creep at idle, leaves traffic lights at 1500-2000rpm.....but if I put my foot down it jumps straight to 5200rpm.
                      • Like Like x 1
                      • Zachow Duster
                        4
                        2
                        Feb 27, 2021
                        Munnsville, NY
                        Local Time:
                        3:01 AM
                        Thanks so much
                      • LO23M8B
                        865
                        414
                        Jan 30, 2019
                        Michigan
                        Local Time:
                        12:01 AM
                        My little 340 loves all 8 inches of it.
