[SOLD] Temp. Sensor connector question??
Mr.FT
New Jersey
Hi,
I have a 1972 340 and my question is where can I find the connector for the temp. sensor. It looks like a little cap that fits over the top of the sensor. I've tried everywhere around my area with no luck. Is there some place on line I could find it?? Anyone have one they want to sell?? Who ever thought this little part would be such a pain.
Thanks
Ton
Let me double check, I am pretty sure I have an extra factory one with about 4" of wire on it.
I think it's the same cap as the gas tank sending unit cap. The wire color is different - purple for the temp sender wire and blue for the gas sending wire. If you don't mind the different color wire I can send you the connector with a length of blue wire.
Its just a 90 degree female terminal for #10 dia' post. They do have fancy extended boot at Mopars temp sender and fuel sender. That's not absolutely required though.
One could browse a pick and pull and collect a bucket full of similar terminals that would work.
